I’m attempting to setup a CPU VLAN for Ubiquiti WAP. This is my lab setup that I’m trying out before applying to my RB2011 but I just realized that these two will take different approaches to VLANs. Guest VLAN is 200 which is specified on the WAP, everything else untagged should be VLAN 100.
RB750GR3 uses the CPU for VLANs but I noticed that in the default config when adding ports ether2 .. 5 it has hw offload on. To enable VLANs here I had to turn it off. How does the router works with this on? Shouldn’t it error out?
One side effect that I didn’t think through is how do I access the WebFig now which I assume is in VLAN 1? I seem to be locked out of the config. Do I setup a management VLAN? I would prefer to access it from VLAN 100. Not sure what the normal approach here is.
Does the configuration below look sane? I combined the MikroTik online Manual with various posts from the forum.
Configuration:
# model = RB750Gr3
add admin-mac=B8:69:F4:AB:32:8A auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=bridge name=vlan100 vlan-id=100
add interface=bridge name=vlan200 vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp_pool1 ranges=10.1.100.100-10.1.100.199
add name=dhcp_pool2 ranges=10.1.200.200-10.1.200.250
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=vlan100 name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=vlan200 name=dhcp2
add bridge=bridge comment=defconf hw=no interface=ether2 pvid=100
add bridge=bridge comment=defconf hw=no interface=ether3 pvid=100
add bridge=bridge comment=defconf hw=no interface=ether4 pvid=100
add bridge=bridge comment=defconf hw=no interface=ether5 pvid=100
/interface bridge vlan
add bridge=bridge tagged=bridge,ether3 vlan-ids=200
add bridge=bridge tagged=bridge untagged=ether2,ether3,ether4,ether5 vlan-ids=100
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.1.100.1/24 interface=vlan100 network=10.1.100.0
add address=10.1.200.1/24 interface=vlan200 network=10.1.200.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.1.100.0/24 gateway=10.1.100.1
add address=10.1.200.0/24 gateway=10.1.200.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
/interface bridge set bridge vlan-filtering=yes
Since you are dealing with non MT devices, keeping it all vlans and not using the bridge as well for dhcp may be easier.
Additions to current setup in blue etc.
What I dont understand is where your 192.168.88 network needs access to??? What do you use it for since its not on any ports???
I will assume it is required on all trunk ports… and since all the access ports are configured with specific vlans already they do not use 192.168.88.1
There is a problem eth3 cannot both be a trunk port and access port …so either its going to devices that are not vlan aware and thus only able to accept one vlanID, or its going to a device that is vlan aware and thus is a trunk port. I am going to assume that this is also a mis-numbering on the bridge port and it should be 200 for eth3.
Lets say that ether 3 is supposed to be on vlan200
Then if its an access port.
add bridge=bridge comment=defconf hw=no interface=ether3 pvid=200
add bridge=bridge tagged=bridge untagged=ether3 vlan-ids=200
Then if its a trunk port.
add address=192.168.88.1/24 comment=defconf interface=base_vlan10 network=192.168.88.0
set allow-remote-requests=yes servers=
8.8.8.8,1.1.1.1,9.9.9.9
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan (this is a left over from the default router setup and can be removed.)
Missing blocking vlans from each other as I expect that is desired ???
To clarify, I’m still learning. The 192.168.X.X network was just something I thought the two VLANs would route through, I didn’t realize it would be dead in the water and not needed.
Further clarification on ether3. It’s a PoE Switch that’s actually plugged in there. One of the devices is WAP which is VLAN aware and serving Home SSID (VLAN 100) and Guest SSID (VLAN 200). However there are other home devices attached to the PoE switch as well which are not smart enough to attach themselves to VLAN 100 by default.
In your updated config below how would I access WebFig for changes?
I also assumed that blocking access from the VLANs to each other would be by default, I was clearly wrong. I see what I’m missing now:
Okay, we are going to modify/replace one rule in the input chain in order to make it more secure and in the forward chain lock it down better and block the vlan200 to vlan100 efficiently.
(1) Input Chain: The rule I am getting rid of: add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
Which basically says drop anything coming into the router not coming from the LAN.
This is a great starter default rule however it lets anybody on your lan talk to the router where we only want the admin to talk to the router.
Why do we need to talk to the router. Two reasons, to use services the router provides (and why the default rule leaves this open from the LAN) AND for the admin to access and change router config.
So we will replace the rule with 3 rules. One to allow the admin to access the router and two/three to allow users to access router dns services.
Finally we are going to add in a drop all else rule at the very end when everything else is working fine on both input and forward chains.
GO TO THE FIRST HALF BELOW… before reading next para.
(2) Forward Chain: What we are going to do here is take one rule and replace it …
Do you know what this rule says or does?
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
Its another great default rule to keep the config safe for new users. Its saying drop all from WAN (incoming unsolicited (originating) from the WAN unless it has a destination port that matches a destination nat rule you have on the router. Bit confusing to read that line and quickly make sense of it for the uninitiated (anytime you use the ! symbol, tread carefully)
So we will replace that rule with a clearer rule. We will also block unwanted traffic and any vlan to vlan traffic by simply as in the input chain, add a last rule to block all other traffic.
The premise here is that if we don’t specifically that specific traffic flow is permitted it will get dropped by the router. Clean and simple.
The obvious traffic we wish to permit is both home and guest access to the internet.
The not so obvious, for example I created a rule to allow admin access to the guest vlan
Lets say you want to give access just to the home printer 10.1.100.115 to guests if they wish to print something.
{input chain}
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1 add action=accept chain=input comment=“Admin Access” in-interface=vlan100 src-address-list=adminaccess
add action=accept chain=input comment=“Allow LAN DNS queries-TCP”
protocol=tcp dst-port=53 in-interface-list=LAN
add action=accept chain=input comment=“Allow LAN DNS queries-UDP”
protocol=ucp dst-port=53 in-interface-list=LAN
add action=drop chain=input comment=“Drop all else”
{forward chain}
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid add action=accept chain=forward comment=“Allow home-guest access to internet” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“Admin Access to Guest VLAN” in-interface=vlan100 src-address-list=adminaccess out-interface=vlan200
add action=accept chain=forward comment=“Guest Access to Printer” in-interface=vlan200 dst-address=10.1.100.115
add action=accept chain=forward comment= “Allow Port Forwarding - DSTNAT”
connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment=“Drop all else”
/ip firewall address-list
add address=ipaddress1 list=adminaccess {for example your desktop)
add address=ipaddress2 list=adminaccess {for example your laptop or ipad}
Note: If you dont do any port forwarding and dont want guest access to printer you can just not include those lines.
Thanks so much. Let me digest this and combine the two threads to see what I get. Also appreciate you going heavy on the firewall as that’s not my strong suit.
It looks like my immediate problem when trying out this config is in the allowed interfaces in the tooling:
[admin@MikroTik] > /tool mac-server
[admin@MikroTik] /tool mac-server> set allowed-interface-list=vlan100
input does not match any value of allowed-interface-list
Not sure if I messed anything up but I see the vlan100|200 interfaces but when I check these settings from the GUI the only options are coming from here:
It appears you never added the interface list members.
On the interface list sub menu (under interfaces) one has to select the box to the right called LISTS…
I tried out the config and most of the things are working, except there is some weirdness around ether3 which has the switch connected to it with the WAP. It looks like this:
ether2, ether4 and ether5 gets the IP from vlan100 - good
ether3 through the poe switch the wap on home vlan100 gets the IP from vlan100 - good
ether3 through the poe switch the wap on home vlan200 gets the IP from vlan200 - good
ether3 through the poe switch for device1 .. 3 gets really confused since these devices are not sending back the explicit vlan100 tag. It doesn’t work till I put this mess back in:
The snippet is the only difference between the config you posted. Here is the full thing:
The way I made this work is having the guest (VLAN 200) show up as tagged traffic on ether3 and assuming everything else, even the home WiFi is untagged as VLAN 100. I looked here: https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Bridge_VLAN_Filtering under “VLAN Example #2 (Trunk and Hybrid Ports)”.
Okay but you didnt answer my questions about ether3?
(1) Is it going to a managed switch or unmanaged switch.
(2) Is the switch connected to any devices which recognize vlans or just PCs, printers etc…
(3) Is the switch connected to a WAP and if so what is the make model?
It’s an unmanaged switch. “TL-SG1005P is a 5 10/100/ 1000Mbps ports unmanaged switch.“ The devices connected currently are printer, camera, Xbox and the WAP.
Going to the dentist is easier then getting answers LOL..
(1) Is it going to a managed switch or unmanaged switch. (answered - good)
(2) Is the switch connected to any devices which recognize vlans or just PCs, printers etc… (partial answer)
(3) Is the switch connected to a WAP and if so what is the make model of the WAP? (partial answer)
Nice AP!, Is there any way to get a direct link to the router via ethernet to the AP, or change the switch to a managed switch or add a small managed switch such that. Meanwhile will see if there are any other alternative approaches.
