Hello Friends i have SXTsq or another model i have problem with CPU while using internet does there is a way to fix the cpu
What kind of problem are you experiencing ? You gave us little information…
bro i have problem cpu increasing to some time 100% at the normal time
What download speeds are you getting ? Can you at least post your configuration ? What exact model do you have ?
There can be various reasons for 100% CPU load
When it happens go to Tools->Profile->Start and post which process is causing high cpu load, eg:
so if j knew the problem that one of those things is there’s a way to fix it
Depends, could be also some fault in OS/HW, but profile with configuration export can help for troubleshooting.
CPU on SXTsq is not powerful, a lot of firewall rules can cause that, etc…
