Home network running MK RB3011 as core router. I found a used CR125-24G for a good price and want to verify that I have it configured right to perform ethernet switching only.
I have 3 Mikrotik access points using wired backhaul to the RB3011. The CR125 allows connection for office servers, printers, workstations. I use port 1 on CR125 to uplink to RB3011.
My question is how do I know the CR125 is using the on-board hardware switching? I've dumped the config for your review but honestly I just don't know what I don't know! LOL
On the CR125 I have disabled the following Packages: Routing, HotSpot, MPLS, PPP, Wireless
Here is the config:
aug/22/2021 10:23:04 by RouterOS 6.48.3
software id = XCFI-3XFI
model = CRS125-24G-1S
serial number = 6D07067E355C
add name=bridge1
add name=WAN
add name=LAN
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
add bridge=bridge1 interface=sfp1
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=ether24 list=LAN
add interface=sfp1 list=LAN
add address=192.168.1.5/24 interface=bridge1 network=192.168.1.0
set servers=192.168.1.1,8.8.8.8
add distance=1 gateway=192.168.1.1
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=Z-Office-Switch-CRS125
/system ntp client
set enabled=yes primary-ntp=192.168.1.1
/system package update
set channel=long-term
