Crashed Hard Disk with RouterOS Level 6
The hardisk where I install RouterOS level 6 has gone bad. How can I get my RouterOs back? I have the ProductID and the License with which it was created.
I hope you must be having latest backup else you have to configure everything again…
Install new hdd & download mikrotikOS same version from http://www.mikrotik.com/download.html
if you want to boot from cd download .ISO file & mount it to make copy disc.
else you can do a net install
http://www.mikrotik.com/testdocs/ros/2.9/guide/netinstall.php
after installing when you login through winbox it will ask you for license key.
