crashing on win98
Just wondering if Dude runs on windows 98 as i have it installed and the server is running but i cannot connect locally to it
This is the error message that i get when i try to connect to DUDE in local
i am using win 98
BUG in dude version 0.1beta14: ASSERT 0 failed in void Pipeserver:connect()at server/servercpp:236
Any suggestions
dude server could not start in Windows 9x due to lack of named pipes, bug fixed.
You will not be able to connect to dude server locally, instead use remote
method with address 127.0.0.1, thank you for your information.
It still does the same thing even when you login remote with 127.0.01
yes, you have to wait for next release.
Still does not work with win 98
Still does not work with win 98 :frowning:(
