The following code when attempt to assign the 5 Ghz A/N mode to 5 Ghz only A mode returns NO ERROR
After that in wireless section we can see that this mode was assigned to adapеer which unsupported it.
And this wlan going to be disabled
This bahavour is fully incorrect and must be return an error.
I use next command to check: /interface wireless set [find name=“wlan1”] band=“5ghz-a/n” ht-rxchains=0,1 ht-txchains=0,1
Return no error to 5 Ghz A only adapter.
The catch on error also not working. The system didn’t executed the on-error section.
The bandwidth also choosen incorrect and assigned it.
But antenna mode worked correct and save previous section
I use the 6.27 firmware with 411UAHR board.
Upgrade RouterOS, I cannot repeat any of your mentioned problems with latest ROS.
If i Do that then our supporting package of scripts going to be messed due to big amount of changes done by your company betwen 6.27 and latest firmware.
The lask of reverse compatibility is a big problem which cause to creating botnets and others problems
The problem reproduce in on only AP bridge mode for me
So I upgraded the router to lastest one.
And error is still going here.
So thank you for incorrect support.
You are the most lazy mikrotik staff which I have seen. THANK YOU for waste of time.
Please post full command entry and output information, maybe you are doing something differently.
