crazy metaaaaal
I’ve downloaded package update metal but after he was taken to the metal prepared run no longer works, and I can not access to it please help
4 Devices gotta Metal stopped on the way
:confused: :confused: :confused:
did you try to connect with MAC address? did you try to use the reset button?
which version was running before, and which file did you specifically upload? with FTP?
