I follow my previous post
I need to create a DHCP for this network.
How can specify which pool use !? I don’t see the option..
Thanks.
Thanks.
BTW. Please, do not start new topic if the old one is more than OK to continue discussion Separate network trough Bridge
Thanks @BartoszP ,
hoo sorry I was thinking it was better to separted, as it’s another question and someone might look for just this. but duly noted.
hoo that where it lay !!! Thanks
but so what’s the difference with webfig/#IP:DHCP_Server.Networks ??
When I enable this newly dhcp server I got invalid… is there somewhere where I could it get more verbose ??
ok I think I found the reason…
So in mikrotik we are forced to use MT Bridge… ![]()
Forced?
If nothing is plugged, what is the problem if DHCP do not work?
hoo so as soon something will be plugged , it will become valid ? and operational ?
if yes I remove what I said.
tested… working..
invalid let think that they are something wrong with the setup..
