Hello
I’m using RB433
Ether3 is 10.0.0.101 and connected to 10.0.0.254(my modem that connect to the internet)
I have a rule in the route
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S ;;; IP of the modem
0.0.0.0/0 10.0.0.254 1
I’m trying to create hotspot while using VAP
I can see I’m connecting to the network and getting IP - but I don’t get the login page
I have reset the html of the hotspot - but still I get nothing
why is that ?
this is the config of the VAP
2 R name="Vap-30_Hotspot" mtu=1500 mac-address=02:15:6D:63:58:5A arp=enabled
interface-type=virtual-AP master-interface=wlan2-2.4Ghz ssid="hotspot" wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default
