Hi
The internet is far from our village , so i want to create network to transfer the ADSL from station1 to station2 then distribution internet to users by access point (wi-fi) as you see in the picture.
notes:
The distance between station1 and station2 less than 3 km.
The users will be about 10 , but I want to be the network capacity to accommodate 40 users.
The ADSL speed will be betwen 4mbps to 16mbps.
I want to make the Wi-Fi signal to cover a distance of 500 to 800 meters.
I need a device for control using the network (for Example Mikrotik RB750GL).
So..
What hardware will I need to create this network ?
What will I need in the station1 ?
What will I need in the station2 ?
Please give me the names of the devices
and what about Mikrotik RB750GL ! Is it good and enough for network like this ?
Please tell me the best choose for me. my English language not so good so please please try to understand what i need exactly
thanks
two sxt in bridge mode plus one omnitik to start more than enough for this link. Buy the omnitik with poe pass through for easy deployment of the station bridge sxt and an extra WiFi AP if it gets to busy. The omnitik will handle 40 users if they are light users but if traffic gets big that can drop to about 20 or less depending on what your users are doing. I would recommend a separate router for your firewalling, user control, etc as the sxt and omnitik have very small CPU. A 750 will probably do to start depending on the complexity of your firewall and queues etc
Hi brothers
Thank you for your interaction ,realy realy thanks.
also i want to ask about RB750GL !
can i use it for 50 or 70 users ?
What is the maximum number of users supported in this device ??
And by the way what it means Karma ? I will give you Karma but how i can do that ?
