Hello, first post here, please go easy ![]()
I am looking to see if I can set up an RB951-2n as a wireless bridge/switch, to function in a similar way to a Cisco WES610n (bridge with 4 port switch). I have a couple non-wifi network components in a room with no Ethernet, and would like to get them connected to the main network. I want the main router to provide the DHCP for the components connected to the bridge.
The main router is an RB2011UiAS-2HnD-IN, with 2 wifi networks created (main, and guest which uses a vlan)
I can get the RB951 to connect to my network using station mode, but where I am stuck is in configuring the rest of the router so the Ethernet ports are properly tied to the wlan.
The steps I have tried (among many) are as follows:
- Set wireless to bridge mode, connect to main wifi.
- Set one single ether port as the master (ether 1, though I have tried other single ports as well).
- Assign the other ether ports to ether 1 (slave).
- Create a bridge and assign both ether 1 and wlan to the bridge.
I have not eliminated any of the factory DHCP, address, pool or other settings. I suspect this may be an issue as well, but I couldn’t find any information regarding this.
So far I have had no luck in getting this to work. My MikroTik experience is modest; I have been studying configurations for months, and have also set up a couple of RB750GL’s.
I have been reading on the forum for months also, but I have not come across the scenario that I am attempting. I do apologize if this is a duplicate.
Any help, or being pointed in the right direction is really appreciated.
Thanks!
