followed this: http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot
After last step got, router disconnected and now can’t log in. I tried to open it in web browser but got redirected to dns name.
any ideas how i can get back in?
Do you remember the user you entered when you set up the hotspot? Use that user/password to login to the hotspot, then you should be able to access the router setup.
yea it was admin with no password.
do i still use the ip address of the router or the dns name i setup?
I was able to get in, but the log had errors, failed to get ip for host, pool empty.
pool empty? How did you setup the hotspot? Please post “/ip hotspot”, “/ip pool”, and “/ip dhcp-server lease”.
in the IP pool i only gave it 2 addresses 172.15.1.148 - 172.15.1.150
I’m guessing that will cause a pool empty fairly quickly.
