Creating "export" file - but not on MT
I would like to crate export file (the same, as MT generates) on my network management system based on PHP. Is there any documentation or class to generate it?
I just want to create file with settings, that I can put to CPE and … it just works :wink:
I know, that I can create “normal” file with commands and import it by the import command, but I’m wondering is this possible to do this in way written above :wink:
M.
Yes, it is possible
http://wiki.mikrotik.com/wiki/Manual:Scripting#Command_line
