Creating "Internet of S**t" VLAN and wireless network + FW and whitelist (1100x2AH with 411AR as access point)
I think that this is more of a general question than wireless, but please feel free to move this thread.
Especially with the current issues with infected Internet of Things [IoT] (aka Internet of Shit) devices forming massive botnets, I want to segregate, isolate, log, and monitor all traffic to my IoT stuff at home. I’m starting with an Ecobee3 Smart WiFi thermostat but eventually want to add other smart home items and cameras. For now though, I just have the Ecobee and it is attached via WiFi.
For my home network, I have an 1100x2AH for the core of my network and a 411AR with a 2.4GHz B/G and 5GHz N card setup currently as follows:
1100x2AH Setup:
  • ether1 is connected to WAN cable modem
  • ether2 is connected to a switch for the rest of the wired network
  • ether3-12 are currently unused
  • ether13 is connected to the 411AR
  • all physical ports in bridge1
  • No existing VLANs
    411:
  • all wifi networks on the 411 are connected to bridge1
  • client wifi networks exists on both the wlan1 and wlan2 attached to the respective interfaces, not virtual
  • a virtual IoT wifi network is setup on wlan1
I’ve taken a look at the documentation and can’t quite follow how to create VLANs and pass them along to wifi networks on the 411, while still leaving the client network endpoints to have an unrestricted network. I know that I’ll need two VLANs, one for internal clients and one for IoT, then put a DHCP server on each VLAN right? ether13 will need to be a trunkport? Willing to change anything about the setup that would make this work easier.
Beyond that, tips for building firewall policies for just the IoT VLAN would be helpful!
What else do you need to know for this project?
Thanks in advance!
I did something similar recently, but at the time I used a CRS125 and a HAP AC Lite. The VLAN configuration for CRS is very different from your equipment, but HAP AC Lite stuff should be the same.
Here’s the wiki that explains VLANs for the 1100 and 433. You need to create a VLAN trunk that contains both of your VLANs between the 1100 and the 433.
http://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features
Here’s a forum topic when I setup mine.
http://forum.mikrotik.com/t/vlan-trunks-without-bridges/95834/1
Oh, and then do one of the following depending on what you want it to have access to (Internet, or LAN/Local nets only)
add action=drop chain=forward comment="Block server from connecting to internet" log=yes log-prefix=ServerTryingToGetOut out-interface=ether1 src-address=10.10.10.20
add action=drop chain=forward comment="Block untrusted network to anything other than WAN" in-interface=vlan30 log=yes log-prefix="Untrusted attempt - " out-interface=!ether1
Some IOT things require an internet connection. Do you know if yours does?
I plan on purchasing some IOT stuff sometime soon too, but I will make sure that it doesn’t require an internet connection to function and will then use a VPN on my phone to connect to my home network in order to use it, blocking any inbound or outbound connections from these devices other than my VPN addresses.
