Credits expire
Dear all
I setup usermanager now worked correctly, but i have problem with Credits expire date, for example 10 hour credites if not used in one month after first login expired automaticly same mobile system???
that is because you are giving them 10 hrs and it starts from the second they first log on , use uptime limit instead and set your credit to 1 month and all should be good for multiple uses totaling 10hrs and exspires in 1 month.
