Hi
We have a problem with 260 series switches. If we set auto-negotiation to disable, and choose a speed and duplex manually, it works OK only till next reboot. After reboot all looks OK, but speed is not working and we have errors in L2. Disable/enable button and it works again, of course till next reboot. We need manual speed settings because it’s only way to connect it to some Cisco devices.
With swos 1.14?
You nowhere wrote if you have this problem with this latest swos firmware?
Therefore I asked you if you use swos 2.14?
Sorry for my rude reply.
Of course 1.14, but problem is probably in all versions (tested with 1.13)
