Croosed or stright
Hi.
A simple question.
When wiring betwen a Router with Mikrotik OS and an MikroTik accespoint, should the cable be crossed or straight?.
It works with both but as i know it should be crossed to secure the best performance, is that correct.
If it should be crossed the best way must be a crossed cable between the router and the PoE injector, correct??
Thanks in advance
Cross or Straight it does not matter,since any of your devices ports supports MDI/MDI-X crossover detection,
in another word if the adapter shows link established it does not matter performance never affected.
Regards.
