CrossRoads - powerpc?
Not clear on routeros version to load on Crossroads. I thougt it used the same processor as the RB133 which should use mipsle. I loaded that package, restared, it upgraded but lists “v3.3 on RB CR (powerpc)”, this confused me a bit. Can anyone clarify what is up with that.
CR uses the same as RB100 and 500 (mipsle). We will fix the download page.
Where I see (powerpc) is at the top of the Winbox window when accessing the Crossroads after upgrading it to v3.3 using the mipsle package.
admin@192.168.10.23 (MikroTik) - WinBox v3.3 on RB CR (powerpc)”
I have 9 of these ready to deploy and want to use v3.3 on them, I want to make sure all is well before upgading them to v3.3.
must be a bug, thanks for reporting it
