crossroads radio info?
Does anyone have any info on the radio in the cross roads board?
mainly what is the minimum Rx sensitivity? is it just a R52?
the Manual on the routerboard.com site is blank under “Output Power and Receive Sensitivity”
thanks
I’ve used quite a few.
Tx power is 26dBm, 24dBm on channels 1 and 11. Receive is pretty good, signal levels read right up to -90dB before dropping, obviously, not a good connection though.
In my experience, same antenna, same cable, same style pigtail and case, one with RB411 and R52H, one Crossroads, the Crossroads gave a 5dB stronger signal.
