Hi!
I have strange problem with this hardware, network traffic is really low, about 15 Mbps max, but CPU is sometimes 100% at 5Mbit/s. There is only simple configuration with
one WAN connection and one lan bridge subnet and simple NAT. Fasttrack is on and not helping at all.
The second question is about dhcp logs:
20:57:13 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:13 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:14 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:14 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:15 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:15 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:17 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:17 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:18 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:18 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:19 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:19 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:21 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:21 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:22 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:22 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:23 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:23 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:25 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:25 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
20:57:26 dhcp,info dhcpd deassigned 192.168.1.96 from 7C:91:22:CD:BB:8D
20:57:26 dhcp,info dhcpd assigned 192.168.1.96 to 7C:91:22:CD:BB:8D
Why there are so many dhcpd assignments to one device ? No matter is it on WiFi or ethernet, every device make logs the same way.
Do you have any solution, or maybe CRS-112 is more switch than router and can’t handle so low traffic ??
