tried to update the device but every time it gives me this error and it does not update the device
CRS 112
CRS 112
Log says your disk drive is full. You have to do something about it.
Sure you want to you use your switch as database server?
i reset configure and same proplem
it’s just like a disk failure
no i just add a bridge
and add port 7 and 8 to the bridge
i reset configure but it's same proplem
it's like a disk faliture
Then why are you trying to run SQL statements?
Can you reset with the option “No Default Configuration”?
Can you post the contents of /file (/file print or screenshot)?
it's showing automatic i don't know why ??
i reset but it's same proplem
The errors in log look like your device is running user manager. As there are errors, it could well be that configuration reset doesn’t fix the problem. The best bet would be netinstall with no default config, after that configure bare minimum (e.g. bridge all port, minimal management access and absolutely nothing else).
