Hi bought myself a CRS125-24G-1S2HnD-IN and would like to connect to my servers from my workstation. Servers have several tagged/untagged VLANs attached so i configure a hybrid port for them. For the workstation i have one untagged vlan (ingress 888) and one tagged vlan (678) . Currently I'm unable to ping the untagged vlan (888) interfaces of the servers and/or the switch from the workstation (interface 23) or from any other servers (interfaces 3-11). Though I can ping the tagged vlans. Did i do anything wrong with ingress/egress translation rules? Please let me know, i'm busy with this for 3 weeks now ... and i can tell ya, trunks/hybrid ports on a CRS aren't easy to config ![]()
[admin@MikroTik] > export
jan/02/1970 07:18:40 by RouterOS 6.23
software id = 09TT-8K3D
/interface wireless
set [ find default-name=wlan1 ] l2mtu=2290
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=ether6 ] master-port=ether2
set [ find default-name=ether7 ] master-port=ether2
set [ find default-name=ether8 ] master-port=ether2
set [ find default-name=ether9 ] master-port=ether2
set [ find default-name=ether10 ] master-port=ether2
set [ find default-name=ether11 ] master-port=ether2
set [ find default-name=ether23 ] master-port=ether2
/interface vlan
add interface=ether2 l2mtu=1584 name=vlan27 vlan-id=27
add interface=ether2 l2mtu=1584 name=vlan34 vlan-id=34
add interface=ether2 l2mtu=1584 name=vlan49 vlan-id=49
add interface=ether2 l2mtu=1584 name=vlan678 vlan-id=678
add interface=ether2 l2mtu=1584 name=vlan888 vlan-id=888
/port
set 0 name=serial0
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether2,ether5,ether8,switch1-cpu vlan-id=27
add tagged-ports=ether2,ether3,ether6,ether10,switch1-cpu vlan-id=34
add tagged-ports=ether2,ether7,ether9,ether11,switch1-cpu vlan-id=49
add tagged-ports="ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ethe
r10,ether11,ether23,switch1-cpu" vlan-id=678
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=888 ports=ether3 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether4 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether5 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether6 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether7 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether8 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether9 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether10 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether11 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether23 sa-learning=yes
add customer-vid=0 new-customer-vid=888 ports=ether2 sa-learning=yes
add ports=ether2,ether5,ether8,switch1-cpu vlan-id=27
add ports=ether2,ether3,ether6,ether10,switch1-cpu vlan-id=34
add ports=ether2,ether7,ether9,ether11,switch1-cpu vlan-id=49
add ports="ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,eth
er11,ether23,switch1-cpu" vlan-id=888
add address=10.8.0.1/24 interface=vlan27 network=10.8.0.0
add address=10.9.0.1/24 interface=vlan34 network=10.9.0.0
add address=10.10.0.1/24 interface=vlan49 network=10.10.0.0
add address=10.11.0.1/24 interface=vlan678 network=10.11.0.0
add address=10.12.0.1/24 interface=vlan888 network=10.12.0.0
add action=drop chain=input comment="default configuration" in-interface=
ether1
add chain=forward comment="default configuration" connection-state=
established,related
add action=drop chain=forward comment="default configuration"
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=ether1
