CRS 125 MAC-based VLAN doesn't work
PC with MAC 40:6C:8F:52:5C:73 connected to ether19 port doesn’t obtain ip-address. But if i connect it to any other access port (10, 14 or 15) all ok (PC obtains address according vlan).
All config was made by CRS Examples in mikrotik wiki, but can’t get working MAC-based vlan.
# jul/09/2015 18:18:42 by RouterOS 6.30
# software id = 0NIS-NCJM
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether1-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether1-master-local name=ether10-slave-local
set [ find default-name=ether11 ] master-port=ether1-master-local name=ether11-slave-local
set [ find default-name=ether12 ] master-port=ether1-master-local name=ether12-slave-local
set [ find default-name=ether13 ] master-port=ether1-master-local name=ether13-slave-local
set [ find default-name=ether14 ] master-port=ether1-master-local name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-master-local name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-master-local name=ether16-slave-local
set [ find default-name=ether17 ] master-port=ether1-master-local name=ether17-slave-local
set [ find default-name=ether18 ] master-port=ether1-master-local name=ether18-slave-local
set [ find default-name=ether19 ] master-port=ether1-master-local name=ether19-slave-local
set [ find default-name=ether20 ] master-port=ether1-master-local name=ether20-slave-local
set [ find default-name=ether21 ] master-port=ether1-master-local name=ether21-slave-local
set [ find default-name=ether22 ] master-port=ether1-master-local name=ether22-slave-local
set [ find default-name=ether23 ] master-port=ether1-master-local name=ether23-slave-local
set [ find default-name=ether24 ] name=ether24-slave-local
set [ find default-name=sfp1 ] name=sfp1-slave-local
/interface vlan
add interface=ether1-master-local l2mtu=1584 name=vlan5 vlan-id=5
add interface=ether1-master-local l2mtu=1584 name=vlan110 vlan-id=110
add interface=ether1-master-local l2mtu=1584 name=vlan113 vlan-id=113
add interface=ether1-master-local l2mtu=1584 name=vlan114 vlan-id=114
/interface ethernet switch
set forward-unknown-vlan=no
/interface ethernet switch trunk
add member-ports=ether5-slave-local,ether6-slave-local name=trunk_uplink_5-6
add member-ports=ether3-slave-local,ether4-slave-local name=trunk_uplink_3-4
add member-ports=ether1-master-local,ether2-slave-local name=trunk_uplink_1-2
/interface ethernet switch egress-vlan-tag
add tagged-ports=trunk_uplink_3-4,trunk_uplink_1-2,switch1-cpu vlan-id=113
add tagged-ports=trunk_uplink_3-4,trunk_uplink_1-2 vlan-id=114
add tagged-ports=trunk_uplink_3-4,trunk_uplink_1-2 vlan-id=110
add tagged-ports=trunk_uplink_3-4,trunk_uplink_1-2 vlan-id=5
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 customer-vlan-format=untagged-or-tagged new-customer-vid=114 ports=ether14-slave-local sa-learning=yes \
    service-vlan-format=untagged-or-tagged
add customer-vid=0 customer-vlan-format=untagged-or-tagged new-customer-vid=5 ports=ether15-slave-local sa-learning=yes \
add customer-vid=0 customer-vlan-format=untagged-or-tagged new-customer-vid=110 ports=ether10-slave-local sa-learning=yes \
/interface ethernet switch mac-based-vlan
add new-customer-vid=114 src-mac-address=40:6C:8F:52:5C:73
set 19 allow-fdb-based-vlan-translate=yes egress-vlan-mode=untagged qos-scheme-precedence=\
    pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
add ports=trunk_uplink_3-4,trunk_uplink_1-2,switch1-cpu vlan-id=113
add ports=trunk_uplink_3-4,trunk_uplink_1-2,ether14-slave-local vlan-id=114
add ports=trunk_uplink_3-4,trunk_uplink_1-2,ether10-slave-local vlan-id=110
add ports=trunk_uplink_3-4,trunk_uplink_1-2,ether15-slave-local vlan-id=5
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=vlan113
The ether19 port is missing in VLAN filtering table (/interface ethernet switch vlan), there are no valid/known VLANs configured on port ether19. Since you have set “forward-unknown-vlan=no” the traffic on ether19 is blocked.
Thank you! That was the key missing in wiki examples.
