hi all
i have one question regarding vlan translation.
i have on spf sfpplus1-telekom 2 vlan-s but one of them (472) i want to translate to vlan 401 and i cannot find anything to work
this is my config
mar/07/2018 18:55:51 by RouterOS 6.41.2
software id = MFSZ-B985
model = CRS226-24G-2S+
serial number = 4C7E044EB571
add name=bridge1-ADAV protocol-mode=none
set [ find default-name=ether1 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether2 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether3 ] advertise=10M-full,100M-full,1000M-full
disabled=yes
set [ find default-name=ether4 ] advertise=10M-full,100M-full,1000M-full mtu=
1572 speed=1Gbps
set [ find default-name=ether5 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether6 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether7 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether8 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether9 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether10 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether11 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether12 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether13 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether14 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether15 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether16 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether17 ] advertise=10M-full,100M-full,1000M-full
speed=1Gbps
set [ find default-name=ether18 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether19 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether20 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether21 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether22 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether23 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=ether24 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no name=
sfpplus1-telekom speed=1Gbps
set [ find default-name=sfpplus2 ] auto-negotiation=no name=sfpplus2-upc
/interface vlan
add interface=bridge1-ADAV name=vlan300 vlan-id=300
/interface ethernet switch
set forward-unknown-vlan=no
add bridge=bridge1-ADAV interface=ether1
add bridge=bridge1-ADAV interface=ether2
add bridge=bridge1-ADAV interface=ether3
add bridge=bridge1-ADAV interface=ether4
add bridge=bridge1-ADAV interface=sfpplus2-upc
add bridge=bridge1-ADAV interface=ether7
add bridge=bridge1-ADAV interface=ether8
add bridge=bridge1-ADAV interface=sfpplus1-telekom
add bridge=bridge1-ADAV interface=ether5
add bridge=bridge1-ADAV interface=ether6
add bridge=bridge1-ADAV interface=ether24
add bridge=bridge1-ADAV interface=ether23
add bridge=bridge1-ADAV interface=ether22
add bridge=bridge1-ADAV interface=ether21
add bridge=bridge1-ADAV interface=ether20
add bridge=bridge1-ADAV interface=ether19
add bridge=bridge1-ADAV interface=ether18
add bridge=bridge1-ADAV interface=ether17
add bridge=bridge1-ADAV interface=ether16
add bridge=bridge1-ADAV interface=ether15
add bridge=bridge1-ADAV interface=ether9
add bridge=bridge1-ADAV interface=ether10
add bridge=bridge1-ADAV interface=ether11
add bridge=bridge1-ADAV interface=ether12
add bridge=bridge1-ADAV interface=ether13
add bridge=bridge1-ADAV interface=ether14
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu,ether4,ether5,ether6 vlan-id=300
add tagged-ports=ether5,sfpplus2-upc vlan-id=165
add tagged-ports=ether5,sfpplus2-upc vlan-id=169
add tagged-ports=ether5,sfpplus2-upc vlan-id=1090
add tagged-ports=ether5,sfpplus2-upc vlan-id=1092
add tagged-ports=ether5,sfpplus2-upc vlan-id=1093
add tagged-ports=ether5,sfpplus2-upc vlan-id=1099
add tagged-ports=sfpplus2-upc vlan-id=164
add tagged-ports=ether1,sfpplus2-upc vlan-id=171
add tagged-ports=ether1,sfpplus2-upc vlan-id=1091
add disabled=yes tagged-ports=sfpplus2-upc vlan-id=1094
add tagged-ports=ether4,sfpplus1-telekom vlan-id=473
add tagged-ports=sfpplus1-telekom vlan-id=472
add tagged-ports=ether1,ether6 vlan-id=401
add tagged-ports=ether1,ether6 vlan-id=403
/interface ethernet switch ingress-vlan-translation
add new-customer-vid=300 ports=switch1-cpu,ether13,ether14
add new-customer-vid=473 ports=ether7
add new-customer-vid=472 ports=ether8
add new-customer-vid=164 ports=ether2
add new-customer-vid=401 ports="ether24,ether23,ether22,ether21,ether20,ether1
9,ether18,ether17,ether16,ether15"
add ports=switch1-cpu,ether1,ether4,ether5,ether6,ether13,ether14 vlan-id=300
add ports=ether5,sfpplus2-upc vlan-id=165
add ports=ether5,sfpplus2-upc vlan-id=169
add ports=ether5,sfpplus2-upc vlan-id=1090
add ports=ether5,sfpplus2-upc vlan-id=1092
add ports=ether5,sfpplus2-upc vlan-id=1093
add ports=ether5,sfpplus2-upc vlan-id=1099
add ports=ether2,sfpplus2-upc vlan-id=164
add ports=ether1,sfpplus2-upc vlan-id=171
add ports=ether1,sfpplus2-upc vlan-id=1091
add disabled=yes ports=sfpplus2-upc vlan-id=1094
add ports=ether4,ether7,sfpplus1-telekom vlan-id=473
add ports=ether8,sfpplus1-telekom vlan-id=472
add ports="ether1,ether6,ether15,ether16,ether17,ether18,ether19,ether20,ether
21,ether22,ether23,ether24" vlan-id=401
add ports=ether1,ether6 vlan-id=403
add address=10.0.0.2/24 interface=vlan300 network=10.0.0.0
set servers=37.153.137.4
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=10.0.0.1
/ip service
set www-ssl disabled=no
/lcd
set backlight-timeout=never default-screen=stats
/lcd interface
set ether1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
set ether11 disabled=yes
set ether12 disabled=yes
set ether13 disabled=yes
set ether14 disabled=yes
set ether15 disabled=yes
set ether16 disabled=yes
set ether17 disabled=yes
set ether18 disabled=yes
set ether19 disabled=yes
set ether20 disabled=yes
set ether21 disabled=yes
set ether22 disabled=yes
set ether23 disabled=yes
set ether24 disabled=yes
set sfpplus2-upc disabled=yes
/system clock
set time-zone-name=Europe/Bucharest
