I am unable to get my CRS 317 to get setup in SWOS. Help!
What does log say ?
Did you change system routerboard setting bootos to swos and then reboot ?
Any other error message ?
i would refuse too
Each time I try to switch to SWOS i get the error message “Not Allowed By Device Mode” I have the CRS resaet to factory default with no config.
Then you first need to change routerboard setting in device mode.
Device-mode - RouterOS - MikroTik Documentation
It’s probably set to something else than ‘advanced’.
I am going to do a full reset with Netinstall
No matter I try it won’t reset to SWOS
Did you change setting for routerboard in device mode ?
Did you after reboot set boot os to SWOS ?
Yes and I unpluged the power lite it said in the description
Can you show output of
/system device print
[admin@MikroTik] > /system device print
mode: home
allowed-versions: 7.13+,6.49.8+
flagged: no
flagging-enabled: yes
scheduler: no
socks: no
fetch: no
pptp: yes
l2tp: yes
bandwidth-test: no
traffic-gen: no
sniffer: no
ipsec: yes
romon: no
proxy: no
hotspot: no
smb: yes
email: no
zerotier: no
container: no
install-any-version: no
partitions: no
-- [Q quit|D dump|down]
You need to first set it to advanced,
/system/device-mode/update mode=advanced
then:
Starting from RouterOS version 7.17 device-mode restricts SwOS/RouterOS transition for dual-boot; in order to enable: system/device-mode/update routerboard=yes
First change device mode to advanced mode.
Reboot
Then change routerboard setting in device mode, as already suggested a couple of times.
Reboot
Then change routerboard/ boot os setting to swos.
Reboot.
I solved my problem.
Step 1) Downgrade router to version 6.49.17
Reboot
Downgrade Routerboard to 6.49.17
Reboot
Login to WEBFIG and change Routerboard to boot into SWOS
Boot in to SWOS was sucessfull
On my laptop I setup the following
I/P 192.168.88.2
Subnet 255.255.255.0
Gateway 8.8.8.8
DNS 8.8.8.8
Login ti 192.168.88.2 was a success!
I hope this helps someone else that is stumped like me. Thanks to all that replyed to my question.
I am absolutely impressed with the help that you get in this formun. Thank all of you for your attention to this matter and I hope I can help someone in the future.
