CRS 326 - Port down after reboot
Hi!
I have some problems with my CRS 326. Some ports stay down after reboot, although there is a device connected.
Disable, reenable also solves the problem until the next restart.
Did you ever see that problem?
  • ROS Versions tested: 6.41.1 and 6.42.3 (same behaviour)
  • Two different devices tested
  • Auto-Negotiation is on
Thank you for your help!
Regards,
Stril
