CRS-328 Copy switch configuration
I Have 5 switches CRS-328 and i want to copy the configuration to the other 4 switches. I made a backup , but it didn’t work , because the backup takes all data ( ip address, mac atc).
Is there any way to copy , just the configuration ? In case the copy is possible from the terminal , could you please inform me the command which i have to use ?
Use the terminal:
/export file=switch
It works
Thank you
