CRS 518-16XS-2XQ
I bought this switch and upgrade the firmware to 7.16.1.
I’m trying to boot SWOS and it is not working.
Do anyone have any information about this?
Unless I missed something on the product page, that device can not use SWOS.
Only ROS.
It can be the option is visible but it will not work.
Search this place, it has been discussed already.
e.g.
http://forum.mikrotik.com/t/need-to-use-crs518-16xs-2xq-rm-as-l2-switch-to-have-port-based-vlan/169643/1
With a beast like that, why would you want to downgrade capabilities and use SWOS ??
X2
I just need to know how to configure it.
I’m aware to configure like a router and make any mess and loose throughput.
As a switch and nothing else:
Start from clean config
Use winbox to connect using MAC
1 bridge
All ports to bridge
Done.
If you need more functionality, you need to be more specific.
For this i understand, but to put a vlan…
The De Facto VLAN guide based on bridge ( works for all ROS devices)
If you want to use dedicated switch chip features, check relevant help pages.
https://help.mikrotik.com/docs/display/ROS/Switch+Chip+Features
Specific CRS3xx, CRS5xx, CCR2116, CCR2216 switch chip features:
https://help.mikrotik.com/docs/display/ROS/CRS3xx%2C+CRS5xx%2C+CCR2116%2C+CCR2216+switch+chip+features
You have to put in some effort too.
Is not going to be delivered on a plate.
Thank you!
Added more specific page with switch chip features.
