CRS 518 VLANs problem
Hi there
Having serious issues with this box. Whenever i activate VLAN filtering in bridge all that comes through is ARP/Broadcasts.
I recieve fine from the core network and can see tagged packets. And everything is working until i want to hardware offload.
# 2025-07-03 11:51:02 by RouterOS 7.18.2
# software id = NE0X-21IC
# model = CRS518-16XS-2XQ
# serial number =
add name=vlan-2025-bridge1
set [ find default-name=qsfp28-1-1 ] l2mtu=9234 mtu=9234 name="100G P1"
set [ find default-name=qsfp28-2-1 ] l2mtu=9234 mtu=9234 name="100G P2"
set [ find default-name=sfp28-2 ] l2mtu=9234 mtu=9216 name="Firewall link"
set [ find default-name=sfp28-16 ] l2mtu=9234 mtu=9234 name="WAN link"
set [ find default-name=ether1 ] l2mtu=2028 mtu=2028 name="ether1 - MGMT"
set [ find default-name=qsfp28-1-2 ] disabled=yes
set [ find default-name=qsfp28-1-3 ] disabled=yes
set [ find default-name=qsfp28-1-4 ] disabled=yes
set [ find default-name=qsfp28-2-2 ] disabled=yes
set [ find default-name=qsfp28-2-3 ] disabled=yes
set [ find default-name=qsfp28-2-4 ] disabled=yes
set [ find default-name=sfp28-3 ] l2mtu=9234 mtu=9216
set [ find default-name=sfp28-4 ] l2mtu=9234 mtu=9216
set [ find default-name=sfp28-5 ] l2mtu=9234 mtu=9216
set [ find default-name=sfp28-6 ] l2mtu=9234 mtu=9216
set [ find default-name=sfp28-15 ] l2mtu=9234 mtu=9234
/interface vlan
add interface=vlan-2025-bridge1 mtu=1584 name=vlan-2025-MGMT-VLAN1000 \
    vlan-id=1000
add interface="Firewall link" mtu=1584 name=vlan-2025-sfp28-2-VLAN100 \
    vlan-id=100
add interface=sfp28-15 mtu=1584 name=vlan-2025-sfp28-15-VLAN10 vlan-id=10
add interface=sfp28-15 mtu=1584 name=vlan-2025-sfp28-15-VLAN100 vlan-id=100
add interface="WAN link" mtu=1584 name=vlan-2025-sfp28-16-VLAN1000 vlan-id=\
    1000
/interface bonding
add lacp-rate=1sec mode=802.3ad mtu=9234 name=vlan-2025-100G-Bond slaves=\
    "100G P1,100G P2" transmit-hash-policy=layer-2-and-3
add lacp-rate=1sec mode=802.3ad mtu=9216 name=vlan-2025-CoreBond slaves=\
    sfp28-5,sfp28-6 transmit-hash-policy=layer-2-and-3
add lacp-rate=1sec mode=802.3ad mtu=9216 name=vlan-2025-NetApp2-Bond slaves=\
    sfp28-3,sfp28-4 transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=vlan-2025-100G-Bond mtu=1584 name=vlan-2025-100G-Bond-VLAN10 \
    vlan-id=10
add interface=vlan-2025-100G-Bond mtu=1584 name=vlan-2025-100G-Bond-VLAN100 \
    vlan-id=100
add interface=vlan-2025-100G-Bond mtu=1584 name=vlan-2025-100G-Bond-VLAN300 \
    vlan-id=300
add interface=vlan-2025-100G-Bond mtu=1584 name=vlan-2025-100G-Bond-VLAN901 \
    vlan-id=901
add interface=vlan-2025-100G-Bond mtu=1584 name=vlan-2025-100G-Bond-VLAN1000 \
    vlan-id=1000
add interface=vlan-2025-CoreBond mtu=9216 name=vlan-2025-CoreBond-VLAN10 \
    vlan-id=10
add interface=vlan-2025-CoreBond mtu=9216 name=vlan-2025-CoreBond-VLAN100 \
    vlan-id=100
add interface=vlan-2025-CoreBond mtu=9216 name=vlan-2025-CoreBond-VLAN300 \
    vlan-id=300
add interface=vlan-2025-CoreBond mtu=9216 name=vlan-2025-CoreBond-VLAN901 \
    vlan-id=901
add interface=vlan-2025-CoreBond mtu=9216 name=vlan-2025-CoreBond-VLAN1000 \
    vlan-id=1000
add interface=vlan-2025-NetApp2-Bond mtu=9216 name=vlan-2025-NetApp2-VLAN10 \
    vlan-id=10
add interface=vlan-2025-NetApp2-Bond mtu=9216 name=vlan-2025-NetApp2-VLAN100 \
    vlan-id=100
add interface=vlan-2025-NetApp2-Bond mtu=9216 name=vlan-2025-NetApp2-VLAN300 \
    vlan-id=300
add interface=vlan-2025-NetApp2-Bond mtu=9216 name=vlan-2025-NetApp2-VLAN901 \
    vlan-id=901
add interface=vlan-2025-NetApp2-Bond mtu=9216 name=vlan-2025-NetApp2-VLAN1000 \
    vlan-id=1000
/port
set 0 name=serial0
add bridge=vlan-2025-bridge1 frame-types=admit-only-vlan-tagged interface=\
/interface bridge vlan
add bridge=vlan-2025-bridge1 tagged="vlan-2025-100G-Bond-VLAN10,vlan-2025-Core\
    Bond-VLAN10,vlan-2025-NetApp2-VLAN10,vlan-2025-sfp28-15-VLAN10,vlan-2025-b\
    ridge1" vlan-ids=10
add bridge=vlan-2025-bridge1 tagged="vlan-2025-100G-Bond-VLAN100,vlan-2025-Cor\
    eBond-VLAN100,vlan-2025-NetApp2-VLAN100,vlan-2025-sfp28-2-VLAN100,vlan-202\
    5-sfp28-15-VLAN100,vlan-2025-bridge1" vlan-ids=100
add bridge=vlan-2025-bridge1 tagged="vlan-2025-100G-Bond-VLAN300,vlan-2025-Cor\
    eBond-VLAN300,vlan-2025-NetApp2-VLAN300" vlan-ids=300
add bridge=vlan-2025-bridge1 tagged="vlan-2025-100G-Bond-VLAN901,vlan-2025-Cor\
    eBond-VLAN901,vlan-2025-NetApp2-VLAN901" vlan-ids=901
add bridge=vlan-2025-bridge1 tagged="vlan-2025-100G-Bond-VLAN1000,vlan-2025-Co\
    reBond-VLAN1000,vlan-2025-NetApp2-VLAN1000,vlan-2025-sfp28-16-VLAN1000,vla\
    n-2025-bridge1" vlan-ids=1000
add address=10.20.30.80/24 interface="ether1 - MGMT" network=10.20.30.0
/system clock
set time-zone-name=Europe/Copenhagen
/system identity
set name="100G Switch"
/system logging
add topics=interface
add topics=firewall
add topics=bridge
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
