Could anyone point me in the right direction regarding my vlan setup.
I have port1 on my RB2011 as WAN with DHCP client, and I have setup 3 vlan interfaces on port2 (vlan 10, 172 and 192). I have configured one DHCP server for each vlan. I have configured a firewall, and basic NAT.
On my CRS125-24G-1G-RM I have setup a switchgroup where ether2-24 has ether1-master as master. I have setup egress vlan tag for vlan 10, 192 and 172 on port1, and also port 2 & 3 for vlan 172. Ether2-16 has ingress vlan translation for vlan 192 - working great and equipment is getting IP from DHCP in 192.168.73.0 subnet, as wanted. Ether23&24 has ingress vlan translation for vlan 10 - also working, getting IP from DHCP in 10.0.0.0 subnet - as wanted
The problem is, I have my Ubiquiti AP AC Lite on port 2 & 3, and have configured a SSID for my private network, and wifi equipment is recieving IP 192.168.73.0 adresses as wanted - there is no vlan settings configured in Ubiquiti controller for this SSID, so this SSID is broadcasting in untagged vlan 192 - perfect. Then I have a second SSID in vlan 172 - where i want 172.16.26.0 adresses - but when connecting to this WiFi, I am not getting IP…
I have tested to configure a ingress vlan translation for vlan 172 on port17 - and then everything is OK - so my problem I am quite shure is on my hybrid vlan config of ether2 & 3
Here is some of my setup on my CRS switch:
[root@MikroTik_Switch] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1-master 1500 E4:8D:8C:A8:56:72 enabled none switch1
1 RS ether2 1500 E4:8D:8C:A8:56:73 enabled ether1-master switch1
2 RS ether3 1500 E4:8D:8C:A8:56:74 enabled ether1-master switch1
3 S ether4 1500 E4:8D:8C:A8:56:75 enabled ether1-master switch1
4 S ether5 1500 E4:8D:8C:A8:56:76 enabled ether1-master switch1
5 S ether6 1500 E4:8D:8C:A8:56:77 enabled ether1-master switch1
6 S ether7 1500 E4:8D:8C:A8:56:78 enabled ether1-master switch1
7 S ether8 1500 E4:8D:8C:A8:56:79 enabled ether1-master switch1
8 S ether9 1500 E4:8D:8C:A8:56:7A enabled ether1-master switch1
9 S ether10 1500 E4:8D:8C:A8:56:7B enabled ether1-master switch1
10 S ether11 1500 E4:8D:8C:A8:56:7C enabled ether1-master switch1
11 RS ether12 1500 E4:8D:8C:A8:56:7D enabled ether1-master switch1
12 S ether13 1500 E4:8D:8C:A8:56:7E enabled ether1-master switch1
13 S ether14 1500 E4:8D:8C:A8:56:7F enabled ether1-master switch1
14 S ether15 1500 E4:8D:8C:A8:56:80 enabled ether1-master switch1
15 S ether16 1500 E4:8D:8C:A8:56:81 enabled ether1-master switch1
16 S ether17 1500 E4:8D:8C:A8:56:82 enabled ether1-master switch1
17 S ether18 1500 E4:8D:8C:A8:56:83 enabled ether1-master switch1
18 S ether19 1500 E4:8D:8C:A8:56:84 enabled ether1-master switch1
19 S ether20 1500 E4:8D:8C:A8:56:85 enabled ether1-master switch1
20 S ether21 1500 E4:8D:8C:A8:56:86 enabled ether1-master switch1
21 RS ether22 1500 E4:8D:8C:A8:56:87 enabled ether1-master switch1
22 S ether23 1500 E4:8D:8C:A8:56:88 enabled ether1-master switch1
23 RS ether24 1500 E4:8D:8C:A8:56:89 enabled ether1-master switch1
24 S sfp1 1500 E4:8D:8C:A8:56:8A enabled ether1-master switch1
[root@MikroTik_Switch] /interface ethernet switch vlan> print
# VLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 D 4095 switch1-cpu no no no no none
1 10 ether1-master no yes no no none
ether23
ether24
2 172 ether1-master no yes no no none
ether2
ether3
3 192 ether1-master no yes no no none
ether2
ether3
ether4
ether5
ether6
ether7
ether8
ether9
ether10
ether11
ether12
ether13
ether14
[root@MikroTik_Switch] /interface ethernet switch ingress-vlan-translation> print
0 ports=ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,
ether13,ether14
service-vlan-format=any customer-vlan-format=any new-customer-vid=192
pcp-propagation=no sa-learning=yes
1 ports=ether23,ether24 service-vlan-format=any customer-vlan-format=any
new-customer-vid=10 pcp-propagation=no sa-learning=yes
2 D ports="" service-vlan-format=any customer-vlan-format=any new-customer-vid=4095
pcp-propagation=no sa-learning=no
[root@MikroTik_Switch] /interface ethernet switch egress-vlan-tag> print
# VLAN-ID TAGGED-PORTS
0 D 4095
1 10 ether1-master
2 192 ether1-master
3 172 ether1-master
ether2
ether3
Please ask if more info is needed to help me out!
