I need bonding LACP under CRS at wire speed (without CPU usage).
Is this posible actually? exists some web with examples?
I need a simple usage, for example:
input in ether1 and output in a ether2/ether3 bonding interface
/interface bonding
add mode=802.3ad name=EtherChannel slaves="ether1 - SW1/0/17,ether2 - SW2/0/17,ether3 - SW1/0/18,ether4 - SW2/0/18,ether5 - SW1/0/19,ether6 - SW2/0/19,ether7 - SW1/0/20,ether8 - SW2/0/20" transmit-hash-policy=\
layer-2-and-3
Works great to my Ciscos… Seems (to my surprise) to balance out rather evenly as well. My CCR’s hardly breaking a sweat CPU wise.
ok!, thanks!
to my best knowledge, LACP is not supported by hw on the crs. to use /interface bonding, the packet must traverse the 1Gig link between the cpu and the switch chip, so you lose a lot more what you could possibly gain. CRS is limited PPS-wise on the CPU to max 240kpps, which tops around 300Mbps…
all you can do is bonding w/o any protocol (e.g ether-channel mode on), somewhere at /inter ethernet switch trunk
Uh-huh…
Port-channel5 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0026.52e8.f994 (bia 0026.52e8.f994)
Description: *
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
reliability 255/255, txload 94/255, rxload 90/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/17 Gi1/0/18 Gi1/0/19 Gi1/0/20
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output 00:00:01, output hang never
Last clearing of “show interface” counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1419901000 bits/sec, 183610 packets/sec
30 second output rate 1440288000 bits/sec, 185085 packets/sec
19160524199 packets input, 19054657271244 bytes, 0 no buffer
Received 23684 broadcasts (61588 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 61588 multicast, 0 pause input
0 input packets with dribble condition detected
19333201452 packets output, 19397019454673 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
I need hw support on CRS… I need wire speed.
honestly, I am not clear if possible after read the posts…
CRS has hw support for LACP?
[quote=“savage”]Uh-huh…
[quote]
crs =/= ccr
I do not understand
,sorry
CRS has hw support for LACP? (yes/no is enough)
The CRS hardware CAN support LACP, but the functionality has not been implemented through the RouterOS software, so there’s no way to configure/control it.
No, CRS does NOT have hw support for bonding nor LACP.
thank you!
It has become very clear.
This is quite a big failing.
IF the chipset supports it mikrotik should implement the support in either routeros or swos.
Another very welcome feature would be virtual chassis and support for MCLAG.
