now set 802.1Q vlan & service vlan can use。but double 802.1Q vlan can‘t to set,how to do?
Hi, a few days ago I had the same problem.
The default service tag type on crs is 802.1ad, but you can overwrite this configuration to 802.1Q for each port.
set ether1 ingress-service-tpid-override=0x8100 egress-service-tpid-override=0x8100
In my case this works perfect.
thanks for you rep.i will try this way ![]()
