Hi
We are installing quite a few CRS switches into a complex, then from there either cat6 or fibre to the end users where they would have their own device such as a Mikrotik hap ac.
The end users would run their own dhcp servers for their own internal networks.
Question is, does the crs switches support DHCP snooping. i.e can I block all ports on the CRS switches from allowing dhcp broadcasts? Often an end user would fiddle around and plug his/her lan cable into another ethernet and there would be dhcp broadcasting around the layer2 network.
Thanks!
