So I am trying to do something similar to a port based VLAN with very specific settings. I need:
Port 1 - Trunk - Tagged VLANs 1/100/1003
Port 2 to 10 - Untagged VLAN 100
Port 11 to 23 - Untagged VLAN 100 and Tagged VLAN 1003
Port 24 - Untagged VLAN 1
I also need to ensure that the VLANs are secured (e.g. “SECURE” mode on the 260GS) such that VLAN 1 isn’t accessible on Port 2 to 23, etc… basically VLANs are only on those ports which they are specified.
I also need VLAN 1 to be on the CPU port and assigned the IP 10.1.1.2/24
All of the rest of the VLANs should just pass through as a switch…
I was trying to use the Port Based VLAN Example (http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Port_Based_VLAN), but that doesn’t seem to have any security or anything… and I also can’t figure out how to get the one port as both tagged and untagged traffic.
What I have so far is:
set [ find default-name=ether1 ] name=ether01-gateway
set [ find default-name=ether2 ] master-port=none name=ether02-master-trunk
set [ find default-name=ether3 ] master-port=ether02-master-trunk name=ether03-slave-trunk
set [ find default-name=ether4 ] master-port=ether02-master-trunk name=ether04-slave-trunk
set [ find default-name=ether5 ] master-port=ether02-master-trunk name=ether05-slave-trunk
set [ find default-name=ether6 ] master-port=ether02-master-trunk name=ether06-slave-trunk
set [ find default-name=ether7 ] master-port=ether02-master-trunk name=ether07-slave-trunk
set [ find default-name=ether8 ] master-port=ether02-master-trunk name=ether08-slave-trunk
set [ find default-name=ether9 ] master-port=ether02-master-trunk name=ether09-slave-trunk
set [ find default-name=ether10 ] master-port=ether02-master-trunk name=ether10-slave-trunk
set [ find default-name=ether11 ] master-port=ether02-master-trunk name=ether11-slave-trunk
set [ find default-name=ether12 ] master-port=ether02-master-trunk name=ether12-slave-trunk
set [ find default-name=ether13 ] master-port=ether02-master-trunk name=ether13-slave-trunk
set [ find default-name=ether14 ] master-port=ether02-master-trunk name=ether14-slave-trunk
set [ find default-name=ether15 ] master-port=ether02-master-trunk name=ether15-slave-trunk
set [ find default-name=ether16 ] master-port=ether02-master-trunk name=ether16-slave-trunk
set [ find default-name=ether17 ] master-port=ether02-master-trunk name=ether17-slave-trunk
set [ find default-name=ether18 ] master-port=ether02-master-trunk name=ether18-slave-trunk
set [ find default-name=ether19 ] master-port=ether02-master-trunk name=ether19-slave-trunk
set [ find default-name=ether20 ] master-port=ether02-master-trunk name=ether20-slave-trunk
set [ find default-name=ether21 ] master-port=ether02-master-trunk name=ether21-slave-trunk
set [ find default-name=ether22 ] master-port=ether02-master-trunk name=ether22-slave-trunk
set [ find default-name=ether23 ] master-port=ether02-master-trunk name=ether23-slave-trunk
set [ find default-name=ether24 ] master-port=none name=ether24-master-management
set [ find default-name=sfp1 ] master-port=ether02-master-trunk name=sfp01-slave-trunk
/interface vlan
add interface=ether02-master-trunk l2mtu=1584 name=vlan-management-ether02 vlan-id=1
add bridge=bridge-management interface=vlan-management-ether02
add address=10.1.0.2/24 comment=Management interface=bridge-management network=10.1.0.0
/interface ethernet switch egress-vlan-translation
add port=ether02 customer-vid=100 new-customer-vid=0
add port=ether03 customer-vid=100 new-customer-vid=0
add port=ether04 customer-vid=100 new-customer-vid=0
add port=ether05 customer-vid=100 new-customer-vid=0
add port=ether06 customer-vid=100 new-customer-vid=0
add port=ether07 customer-vid=100 new-customer-vid=0
add port=ether08 customer-vid=100 new-customer-vid=0
add port=ether09 customer-vid=100 new-customer-vid=0
add port=ether10 customer-vid=100 new-customer-vid=0
add port=ether11 customer-vid=100 new-customer-vid=0
add port=ether12 customer-vid=100 new-customer-vid=0
add port=ether13 customer-vid=100 new-customer-vid=0
add port=ether14 customer-vid=100 new-customer-vid=0
add port=ether15 customer-vid=100 new-customer-vid=0
add port=ether16 customer-vid=100 new-customer-vid=0
add port=ether17 customer-vid=100 new-customer-vid=0
add port=ether18 customer-vid=100 new-customer-vid=0
add port=ether19 customer-vid=100 new-customer-vid=0
add port=ether20 customer-vid=100 new-customer-vid=0
add port=ether21 customer-vid=100 new-customer-vid=0
add port=ether22 customer-vid=100 new-customer-vid=0
add port=ether23 customer-vid=100 new-customer-vid=0
add port=ether24 customer-vid=1 new-customer-vid=0
/interface ethernet switch ingress-vlan-translation
add port=ether02 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether03 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether04 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether05 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether06 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether07 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether08 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether09 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether10 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether11 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether12 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether13 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether14 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether15 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether16 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether17 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether18 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether19 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether20 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether21 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether22 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether23 customer-vid=0 new-customer-vid=100 sa-learning=yes
add port=ether24 customer-vid=0 new-customer-vid=1 sa-learning=yes
