CRS - How to get stats by interface?
Hi all,
I’m new using Mikrotik and RouterOS. I’ve setup some CRS in our network, and have some troubles.
I put a simple config at CRS:
  • ether2: master port.
  • ether3 to ether24: slave ports of ether2.
I think (after read some manuals, posts, etc…) that this is the correct way to get ether2 -to- ether24 working as switch ports, using switch chip and at wire speed (1 Gbps by port).
But I see this in my stats:
All ports have the same Tx traffix (Rx traffic is different by port). Why?
In my others switchs, I get stats from every port independent. Here, I’m getting same Tx stats in all ports (I think that this is the sum of all Tx traffic of all switch ports).
So, how can get REAL traffic stats by port?
Thanks!
SOLVED:
There’s a bug in v6.7, described here:
http://forum.mikrotik.com/t/6-6-to-6-7-crs-very-slow-lan-speed/72330/1
Using v6.7 I get all traffic “duplicated” in all switch ports.
After downgraded to v6.6, problem was solved, and I get traffic per interface in stats.
Waiting for new RouterOS version to be updated with this thing solved :slight_smile:
Yep. It’s a bug.
Sent from my SCH-I545 using Tapatalk
Still broken in 6.8rc1
