Anybody else having issues with MAC learning on CRS series?
I’ve just deployed a CRS125-24G-1S and at first everything seemed fine, but after a few minutes we started noticing a communication problems.
There seems to be a limit for the number of MAC addresses the CRS can learn. We couldn’t reach 2000 addresses in the FDB unicast table, while the RB1100AHx2 this CRS was supposed to replace have about 2700 host entries on the bridge hosts table.
I’ve been digging the CRS documentation and may have found the problem:
learn-override (yes | no; Default: !learn-override)
learn-limit (1..1023; Default: !learn-limit)
Enable or disable MAC address learning and set MAC limit on the port. By default, when !learn-override and !learn-limit, MAC learning is enabled with max allowed limit - 1024.
Can anyone confirm the CRS supports at most 1024 MAC address per port? It’s kind of a deal breaker…
Could you pass this for winbox addition please? There’s no time period shown or available in winbox (I’m using winbox 3 but it’s not in 2 either) but in
IPv6 firewall / address lists
There’s no timer field only ip and name
Most annoying on IPv6 lists you have no idea of the remaining time…
