CRS management vlan
I vlan a CRS switch by “interface ethernet switch vlan” and add switch1-cpu to one of vlans.
i connect CRS to a router and vlan it by “interface vlan” and “interface bridge” commands
know, i can manage the switch by using a PC that directly connected to the switch or is inside the vlan that switch1-cpu is on it.
But the problem is
1-i can not connect to each CRS from other ones by ip address
2-I can not connect to CRS switch from outside the lan. Even i define routes properly.
is anybody can help me how to manage CRS switches?
