CRS not passing traffic to access ports
Hi, just got a brand new CRS125-24G-1S and I'm trying to figure out the configuration. Right now I'm attempting to create a simple setup like this:
Cisco3550 <-------trunk vlans 1,59--------> CRS125-24G-1S <-----access vlan 59-----> PC
ether24 is a trunk port where only VLANs 1 (default) and 59 are permitted.
ether1 is an access port (vlan59) with a workstation attached to it (my PC).
CRS is accessible by ping on the default VLAN.
The problem is: CRS is not passing traffic to my PC. My PC does not see any traffic from VLAN59.
What's the problem? Am I getting something wrong?
apr/14/2014 19:11:06 by RouterOS 6.10
software id = IKDF-GH6M
set [ find default-name=ether1 ] master-port=ether24
/interface ethernet switch
set bridge-type=customer-vlan-bridge
/interface ethernet switch egress-vlan-translation
add customer-vid=59 new-customer-vid=0 port=ether1
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=59 port=ether1 sa-learning=yes
add ports=ether1,ether24 sa-learning=yes vlan-id=59Cisco setup
interface FastEthernet0/35
switchport access vlan 28
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 1,59
switchport mode trunk
switchport nonegotiate
Anyone?
In RouterOS v6.10 configure this without a VLAN table entry:
Thank you, that worked. But how do I restrict which VLANs are allowed on trunk ports and which are not then?
VLAN filtering will be available starting from RouterOS v6.12:
http://wiki.mikrotik.com/wiki/Manual:CRS_examples
