CRS Routing?
HI All,
Just got my first CRS. it looks very promising, the LCD is a nice thing to have on a switch instead of a name label and IP also the port infor is great.
And it is silent as well:D
One thing I’m not sure is where is the layer 3 switching? should I configure IP the normal way, once I do that I’m able to connect with Winbox so it goes to the cpu.
It looks like a very nice layer 2 switch with a small router.
Default configuration for my devices were:
ether1-gateway=wan
sfp1-gateway=wan
bridge1-local=lan
Switch Port 1 and SFP goes to Internet and the rest of the ports goes to lan devices.
True this is the default configuration.
But this routing is done by software.
I was under the impression that basic routing will be done by hardware.
Do you mean hardware fast path? I do not think that this feature is complete yet, or available for this product.
Here is what normis wrote about it.
http://forum.mikrotik.com/t/6-5-released/70665/167
Thanks.
There is something strange in the title of the product a layer 3 switch.
From wikipedia
The only difference between a layer 3 switch and router is the way the administrator creates the physical implementation. Also, traditional routers use microprocessors to make forwarding decisions, and the switch performs only hardware-based packet switching. However, some traditional routers can have other hardware functions as well in some of the higher-end models. Layer 3 switches can be placed anywhere in the network because they handle high-performance LAN traffic and can cost-effectively replace routers. Layer 3 switching is all hardware-based packet forwarding, and all packet forwarding is handled by hardware ASICs. Layer 3 switches really are no different functionally than a traditional router and perform the same functions, which are listed here.
Don’t get me wrong the CRS sounds like a great product with no documentation for now.
as discussed elsewhere here, that is really what it is.
ARBEIT ANGST KONSUMTERROR
