CRS switch (CRS125) and wired RADIUS authentication
I am successfully using RADIUS together with Mikrotik/RouterOS to authenticate wireless clients on APs.
Now, I would like to do an analogous thing with CRS switch (CRS125).
1 port = 1 MAC (client).
I would like to configure CRS125 to authenticate a client attached to a port against our RADIUS server, i.e. “Wired radius MAC authentication”.
If a MAC attached to a port is found in RADIUS database, then port should go to the forwarding state, otherwise should be in a blocking state.
Could you please confirm, whether such solution is possible with CRS125/Mikrotik/Routeros switch?
Thank you very much.
Jan
Were you able to achieve your desired configuration?
I am also interessted in those setup,
can you give an feedback if you get that working?
