Marvell 98DX3236
CRS326-24G-2S+
6.46.7 (long-term)
Synopsis: Switch is an edge switch connecting access L2 links from different services providers (about 6), meaning 6 trunks from service providers. Sometimes you might get into a situation where service providers X and Y would provide the same VLAN ID or maybe a VLAN ID which already exists within your environment.
The solution would be to change VLAN IDs as they come through from each service provider, this way - I have control & a bit of independence on internal VLAN management.
(me)CCR - IP 192.168.52.1 /25 Vlan 500
SW2 - VLAN 500 passed through
SW1 - VLAN500 converted to VLAN 400
L2ISPX VLAN 400
Client CPE VLAN 400 IP 192.168.52.2/25
Objective: change VLAN ID from different ISPs to avoid VLAN ID conflict.
_/interface bridge export
add arp=disabled name=bridge-Switch priority=0xE000 vlan-filtering=yes
add bridge=bridge-Switch interface=ether2
add bridge=bridge-Switch interface=ether23
/interface bridge vlan
add bridge=bridge-Switch comment=“Converted VLAN” tagged=ether2,ether23-CRS-SW vlan-ids=500
/interface ethernet switch rule
add new-vlan-id=500 ports=ether2 switch=switch1 vlan-header=present vlan-id=400_
VLAN comes through(from ISP) tagged (SW1) on Ether 2 Vlan 400, change it to VLAN 500, pass it on as VLAN 500 to SW2 2 on ether 23.
All ports are in a switch group with Hardware offload and VLAN filtering activated.
ISP VLAN 400
Have applied the above for the setup and also tried different options, no luck.
What am i missing?
Would be glad if anyone has done this succefully?
