Hi
I’m trying to configurate my CRS with tagged and unntagged vlan, and I’m facing a loop problem, witch i did not understand where this loop is in my configuration.
Can any expert here see and help me with this?
interface ethernet
set [ find default-name=ether1 ] master-port=sfpplus2
set [ find default-name=ether2 ] master-port=sfpplus2
set [ find default-name=ether3 ] master-port=sfpplus2
set [ find default-name=ether4 ] master-port=sfpplus2
set [ find default-name=ether5 ] master-port=sfpplus2
set [ find default-name=ether6 ] master-port=sfpplus2
set [ find default-name=ether7 ] master-port=sfpplus2
set [ find default-name=ether8 ] master-port=sfpplus2
set [ find default-name=ether9 ] master-port=sfpplus2
set [ find default-name=ether10 ] master-port=sfpplus2
set [ find default-name=ether11 ] master-port=sfpplus2
set [ find default-name=ether12 ] master-port=sfpplus2
set [ find default-name=ether13 ] master-port=sfpplus2
set [ find default-name=ether14 ] master-port=sfpplus2
set [ find default-name=ether15 ] master-port=sfpplus2
set [ find default-name=ether16 ] master-port=sfpplus2
set [ find default-name=ether17 ] master-port=sfpplus2
set [ find default-name=ether18 ] master-port=sfpplus2
set [ find default-name=ether19 ] master-port=sfpplus2
set [ find default-name=ether20 ] master-port=sfpplus2
set [ find default-name=ether21 ] master-port=sfpplus2
set [ find default-name=ether22 ] master-port=sfpplus2
set [ find default-name=ether23 ] master-port=sfpplus2
set [ find default-name=ether24 ] master-port=sfpplus2
/interface vlan
add interface=sfpplus2 name=VLAN4078 vlan-id=4078
add interface=sfpplus2 name=VLAN1919 vlan-id=1919
add interface=sfpplus2 name=VLAN2016 vlan-id=2016
add interface=sfpplus2 name=VLAN2001 vlan-id=2001
add interface=sfpplus2 name=VLAN2009 vlan-id=2009
add interface=sfpplus2 name=VLAN798 vlan-id=798
add interface=sfpplus2 name=VLAN782 vlan-id=782
add interface=sfpplus2 name=VLAN783 vlan-id=783
add interface=sfpplus2 name=VLAN790 vlan-id=790
add interface=sfpplus2 name=VLAN784 vlan-id=784
add interface=sfpplus2 name=VLAN786 vlan-id=786
add interface=sfpplus2 name=VLAN785 vlan-id=785
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu,sfpplus2,ether24,ether23,ether1 vlan-id=4078
add tagged-ports=switch1-cpu,sfpplus2,ether24,ether1 vlan-id=1919
add tagged-ports=switch1-cpu,sfpplus2,ether24,ether1 vlan-id=2001
add tagged-ports=switch1-cpu,sfpplus2,ether24,ether1 vlan-id=2016
add tagged-ports=switch1-cpu,sfpplus2,ether24,ether1 vlan-id=2009
add tagged-ports=switch1-cpu,sfpplus2,ether23 vlan-id=798
add tagged-ports=switch1-cpu,sfpplus2,ether23,ether1 vlan-id=782
add tagged-ports=switch1-cpu,sfpplus2,ether23,ether1 vlan-id=783
add tagged-ports=switch1-cpu,sfpplus2,ether22,ether1 vlan-id=790
add tagged-ports=switch1-cpu,sfpplus2,ether22,ether1 vlan-id=785
add tagged-ports=switch1-cpu,sfpplus2,ether22,ether1 vlan-id=784
add tagged-ports=switch1-cpu,sfpplus2,ether22,ether1 vlan-id=786
/interface ethernet switch egress-vlan-translation
add customer-vid=2001 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether2,ether3,ether4,ether5,ether6,ether7,ether8 service-vlan-format=untagged-or-tagged
add customer-vid=1919 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether9,ether10 service-vlan-format=untagged-or-tagged
add customer-vid=2009 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether11,ether12 service-vlan-format=untagged-or-tagged
add customer-vid=2016 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether13,ether14 service-vlan-format=untagged-or-tagged
add customer-vid=798 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether15,ether1 service-vlan-format=untagged-or-tagged
add customer-vid=782 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether16 service-vlan-format=untagged-or-tagged
add customer-vid=783 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether17 service-vlan-format=untagged-or-tagged
add customer-vid=790 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether18 service-vlan-format=untagged-or-tagged
add customer-vid=785 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether19 service-vlan-format=untagged-or-tagged
add customer-vid=784 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether20 service-vlan-format=untagged-or-tagged
add customer-vid=786 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether21 service-vlan-format=untagged-or-tagged
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=2001 ports=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8
add customer-vid=0 new-customer-vid=1919 ports=ether9,ether10
add customer-vid=0 new-customer-vid=2009 ports=ether11,ether12
add customer-vid=0 new-customer-vid=2016 ports=ether13,ether14
add customer-vid=0 new-customer-vid=798 ports= ether15
add customer-vid=0 new-customer-vid=782 ports= ether16
add customer-vid=0 new-customer-vid=783 ports= ether17
add customer-vid=0 new-customer-vid=784 ports= ether20
add customer-vid=0 new-customer-vid=785 ports= ether19
add customer-vid=0 new-customer-vid=786 ports= ether21
add customer-vid=0 new-customer-vid=790 ports= ether18
add ports=switch1-cpu,sfpplus2,ether24 vlan-id=4078
add ports=switch1-cpu,sfpplus2,ether24,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-id=2001
add ports=switch1-cpu,sfpplus2,ether24,ether9,ether10 vlan-id=1919
add ports=switch1-cpu,sfpplus2,ether24,ether11,ether12 vlan-id=2009
add ports=switch1-cpu,sfpplus2,ether24,ether13,ether14 vlan-id=2016
add ports=switch1-cpu,sfpplus2,ether23,ether15 vlan-id=798
add ports=switch1-cpu,sfpplus2,ether23,ether16 vlan-id=782
add ports=switch1-cpu,sfpplus2,ether23,ether17 vlan-id=783
add ports=switch1-cpu,sfpplus2,ether22,ether20 vlan-id=784
add ports=switch1-cpu,sfpplus2,ether22,ether19 vlan-id=785
add ports=switch1-cpu,sfpplus2,ether22,ether21 vlan-id=786
add ports=switch1-cpu,sfpplus2,ether22,ether18 vlan-id=790
/system routerboard settings
set protected-routerboot=disabled
