*) l3hw - added initial HW offloading for VXLAN on compatible switches;
I’m trying to setup a 3 node proxmox cluster using VXLAN, where nodes talk to each other using VXLAN + to the switch, which “unfolds” VNIs into VLANs for the rest of the network.
However, I’m failing to get any hw-offloading running (cpu tops out at 100% ~1Gbps traffic on VXLAN). in the docs I’ve spotted that:
Underlay (routing encapsulated VXLAN packets):
2. VTEPs are not supported over bond, VLAN interfaces,
It’s a bit confusing, as all the other bullet points on this list mention only 1 thing, and this one mentions 2 with a comma (is it an OR or an AND).
Does that mean, that my CRS310-8G+2S+IN can’t communicate over VLAN interfaces to the VTEPs?
I tried to add address directly on bridge and pvid 1 (to try to avoid vlans) but to no avail.
Current documentation has only 1 example with dedicated direct port to the VTEP (which is kinda lame).
Is there a way to bridge VTEPs as well as communicate with them on the same device?
That does explain why I’m having performance issue (reading is hard), but doesn’t really fully answer the question.
If I take existing config and pass the vlan 100 to a CRS309-1G-8S+ (which does support hw-offload VLAN), would that work?
Can i pass the vlan100(vxlan(packet)), or do I need to pass raw vxlan(packet)?
As I understand it, these restriction only apply for hw-offloaded VXLAN, which is not supported on CRS310.
Passing vlan100(vxlan(packet)) on CRS310 should work.
And as you have experienced, doing VXLAN on CPU severely limits bandwidth.
I’m rephrasing the question again with regard to CRS309-1G-8S+, which does support L3HW VXLAN.
Can I have (multiple) VTEPs on bridge (preferably on tagged vlan) AND communicate with them while having L3HW VXLAN working, or do I have to provide CRS309 with dedicated port that carries raw VXLAN packets? If the question is still unclear - can communication with a VTEP be performed over tagged VLAN?
I see. The described limitation seems to be about VTEPs directly on top of a VLAN interface.
Your question is about forwarding VTEP packets to tagged ports on the same bridge.
Good question and I don’t know the answer. Depending on the switch ASIC, this technically should work if done right.
The best way is probably to just give it a try. Or ask MT support.
Hi everyone, I’ve been testing VXLAN in hardware offload through two switches. HW3 active, management VLAN, all configurations on the bridge, VXLAN done, added to the bridge, VXLAN hardware offload is active. But I noticed, I believe it’s what the documentation says, there’s no way to pass VLAN tag inside the tunnel, I don’t know if anyone has managed to do this.
