Im tring to do configuration that seems impossible because in CRS u must set master port.
What i need is
Client side
ether1 belongs in vlan 10-12
ether2 belongs in vlan 10-12
ether3 belongs in vlan 10-12
ether4 belongs in vlan 10-12
ether5 belongs in vlan 10-12
ether6 belongs in vlan 10-12
ether7 belongs in vlan 10-12
ether8 belongs in vlan 10-12
Server side
ether24 belongs in vlan 12
ether23 belongs in vlan 11
ether22 belongs in vlan 10
eq: is if a client comes from vlan 11 no metter what port should go to server in ether23
I don’t have a CRS yet, although hopefully my first will arrive tomorrow.
However, I’m not sure your question makes sense, or rather, whether this is the correct way to use VLANs.
Are ether1-8, which I assume are your clients, tagged (aka trunked) ports? ie you have a separate LAN for each server?
The way you are trying to set it up you would need three separate interfaces on each client in order to separate the traffic. Is this really what you want?
In general you should consider, if you want to do with VLAN than you need to add the VLAN Tag to the Packet before it processed by the switch internal. May be in your case this could be done either :
a. by the client, than you have to add the port as ‘tagged’ port to the VLANs
b. the client not use tagging, than the ‘port’ should add/remove the Tag, therefor you need to define an ingress translation.
May be MAC or Protocol based VLAN are also an possible solution.
