I received a CRS125-24G-1S-RM on Friday and since then I've been trying to get a management IP assigned to a VLAN. I've been following the CRS examples guide and have managed to get a port based VLAN working (except that it leaks tagged traffic from other VLANs, but from what I hear that's the best that can be done at the moment). Down at the bottom of the page, it explains how to set a management IP for the VLAN, which I'd like to do so that the switch can act as the gateway. However, it doesn't seem to work.
I ran Wireshark on a host in the VLAN and attempted to ping it from the switch. In Wireshark, I can see the ARP requests from the switch (untagged) and the ARP responses from the host (also untagged). I've even reset the configuration of the router (removing what I already had configured) and tried just the VLAN configuration from scratch, but no luck. My export is below. Does anyone know what I'm doing wrong? Does anyone have this working?
[admin@MikroTik] > export
jan/02/1970 00:35:59 by RouterOS 6.11
software id = 76PM-XHVB
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether1-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether1-master-local name=ether10-slave-local
set [ find default-name=ether11 ] master-port=ether1-master-local name=ether11-slave-local
set [ find default-name=ether12 ] master-port=ether1-master-local name=ether12-slave-local
set [ find default-name=ether13 ] master-port=ether1-master-local name=ether13-slave-local
set [ find default-name=ether14 ] master-port=ether1-master-local name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-master-local name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-master-local name=ether16-slave-local
set [ find default-name=ether17 ] master-port=ether1-master-local name=ether17-slave-local
set [ find default-name=ether18 ] master-port=ether1-master-local name=ether18-slave-local
set [ find default-name=ether19 ] master-port=ether1-master-local name=ether19-slave-local
set [ find default-name=ether20 ] master-port=ether1-master-local name=ether20-slave-local
set [ find default-name=ether21 ] master-port=ether1-master-local name=ether21-slave-local
set [ find default-name=ether22 ] master-port=ether1-master-local name=ether22-slave-local
set [ find default-name=ether23 ] master-port=ether1-master-local name=ether23-slave-local
set [ find default-name=ether24 ] master-port=ether1-master-local name=ether24-slave-local
set [ find default-name=sfp1 ] master-port=ether1-master-local name=sfp1-slave-local
/interface vlan
add interface=ether1-master-local l2mtu=1584 name=vlan200 vlan-id=200
/interface ethernet switch
set bridge-type=customer-vid-used-as-lookup-vid
/port
set 0 name=serial0
/interface ethernet switch egress-vlan-translation
add customer-vid=200 new-customer-vid=0 ports=ether2-slave-local
add customer-vid=200 new-customer-vid=0 ports=ether3-slave-local
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=200 ports=ether2-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=200 ports=ether3-slave-local sa-learning=yes
add address=192.168.88.1/24 comment="default configuration" interface=ether1-master-local network=192.168.88.0
add address=192.168.1.1/24 interface=vlan200 network=192.168.1.0
/ip upnp
set allow-disable-external-interface=no
/lcd interface
set ether1-master-local interface=ether1-master-local
set ether2-slave-local interface=ether2-slave-local
set ether3-slave-local interface=ether3-slave-local
set ether4-slave-local interface=ether4-slave-local
set ether5-slave-local interface=ether5-slave-local
set ether6-slave-local interface=ether6-slave-local
set ether7-slave-local interface=ether7-slave-local
set ether8-slave-local interface=ether8-slave-local
set ether9-slave-local interface=ether9-slave-local
set ether10-slave-local interface=ether10-slave-local
set ether11-slave-local interface=ether11-slave-local
set ether12-slave-local interface=ether12-slave-local
set ether13-slave-local interface=ether13-slave-local
set ether14-slave-local interface=ether14-slave-local
set ether15-slave-local interface=ether15-slave-local
set ether16-slave-local interface=ether16-slave-local
set ether17-slave-local interface=ether17-slave-local
set ether18-slave-local interface=ether18-slave-local
set ether19-slave-local interface=ether19-slave-local
set ether20-slave-local interface=ether20-slave-local
set ether21-slave-local interface=ether21-slave-local
set ether22-slave-local interface=ether22-slave-local
set ether23-slave-local interface=ether23-slave-local
set ether24-slave-local interface=ether24-slave-local
set sfp1-slave-local interface=sfp1-slave-local
/lcd interface pages
set 0 interfaces="ether1-master-local,ether2-slave-local,ether3-slave-local,ether4-slave-local,ether5-slave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether10-slave-l
ocal,ether11-slave-local,ether12-slave-local"
set 1 interfaces="ether13-slave-local,ether14-slave-local,ether15-slave-local,ether16-slave-local,ether17-slave-local,ether18-slave-local,ether19-slave-local,ether20-slave-local,ether21-slave-local,ether22
-slave-local,ether23-slave-local,ether24-slave-local"
