CRS with Vlan Filter and IGMP Snooping
Hi there,
my Config is:
set [ find default-name=qsfpplus1-1 ] l2mtu=1592
set [ find default-name=qsfpplus1-2 ] l2mtu=1592
set [ find default-name=qsfpplus1-3 ] l2mtu=1592
set [ find default-name=qsfpplus1-4 ] l2mtu=1592
set [ find default-name=qsfpplus2-1 ] l2mtu=1592
set [ find default-name=qsfpplus2-2 ] l2mtu=1592
set [ find default-name=qsfpplus2-3 ] l2mtu=1592
set [ find default-name=qsfpplus2-4 ] l2mtu=1592
set [ find default-name=sfp-sfpplus1 ] l2mtu=1592 name=sfp-sfpplus1
set [ find default-name=sfp-sfpplus2 ] l2mtu=1592 name=sfp-sfpplus2
set [ find default-name=sfp-sfpplus3 ] l2mtu=1592 name=sfp-sfpplus3
set [ find default-name=sfp-sfpplus4 ] l2mtu=1592 name=sfp-sfpplus4
set [ find default-name=sfp-sfpplus5 ] l2mtu=1592 name=sfp-sfpplus5
set [ find default-name=sfp-sfpplus6 ] l2mtu=1592 name=sfp-sfpplus6
set [ find default-name=sfp-sfpplus7 ] l2mtu=1592 name=sfp-sfpplus7-multicast-tv
set [ find default-name=sfp-sfpplus8 ] l2mtu=1592
set [ find default-name=sfp-sfpplus9 ] l2mtu=1592 name=sfp-sfpplus9
set [ find default-name=sfp-sfpplus10 ] l2mtu=1592 name=sfp-sfpplus10
set [ find default-name=sfp-sfpplus11 ] l2mtu=1592 name=sfp-sfpplus11
set [ find default-name=sfp-sfpplus12 ] l2mtu=1592
set [ find default-name=sfp-sfpplus13 ] l2mtu=1592
set [ find default-name=sfp-sfpplus14 ] l2mtu=1592
set [ find default-name=sfp-sfpplus15 ] l2mtu=1592
set [ find default-name=sfp-sfpplus16 ] l2mtu=1592
set [ find default-name=sfp-sfpplus17 ] l2mtu=1592
set [ find default-name=sfp-sfpplus18 ] l2mtu=1592
set [ find default-name=sfp-sfpplus19 ] l2mtu=1592
set [ find default-name=sfp-sfpplus20 ] l2mtu=1592
set [ find default-name=sfp-sfpplus21 ] l2mtu=1592
set [ find default-name=sfp-sfpplus22 ] l2mtu=1592
set [ find default-name=sfp-sfpplus23 ] l2mtu=1592
set [ find default-name=sfp-sfpplus24 ] l2mtu=1592 name=sfp-sfpplus24-adm
add admin-mac=D2:57:BC:69:1D:A1 auto-mac=no name=bridge1 protocol-mode=none pvid=30 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan30-mgnt vlan-id=30
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus2
add bridge=bridge1 interface=sfp-sfpplus4
add bridge=bridge1 interface=sfp-sfpplus5 multicast-router=disabled
add bridge=bridge1 interface=sfp-sfpplus7-multicast-tv pvid=152
add bridge=bridge1 interface=sfp-sfpplus9
add bridge=bridge1 frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=sfp-sfpplus10
add bridge=bridge1 frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=sfp-sfpplus11
add bridge=bridge1 interface=sfp-sfpplus6 pvid=30
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1,sfp-sfpplus9,sfp-sfpplus10,sfp-sfpplus11 untagged=sfp-sfpplus6 vlan-ids=30
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus10,sfp-sfpplus11 vlan-ids=161
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus9l vlan-ids=31
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus9 vlan-ids=32
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus7-multicast-tv vlan-ids=151
add bridge=bridge1 tagged=sfp-sfpplus1-uplink,sfp-sfpplus10,sfp-sfpplus11 vlan-ids=11
add bridge=bridge1 tagged=sfp-sfpplus1-uplink,sfp-sfpplus11 vlan-ids=21
add bridge=bridge1 tagged=sfp-sfpplus1-uplink untagged=sfp-sfpplus7-multicast-tv vlan-ids=152
add address=10.2.0.3/16 interface=vlan30-mgnt network=10.2.0.0
add distance=1 gateway=10.2.0.1
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Berlin
/system identity
set name=crs
/system ntp client
set enabled=yes primary-ntp=10.2.0.13 secondary-ntp=10.2.0.13
/system routerboard settings
set auto-upgrade=yes boot-os=router-os enter-setup-on=delete-key
When i enable IGMP Snooping on the Bridge, Multicast to “add bridge=bridge1 tagged=sfp-sfpplus1-uplink untagged=sfp-sfpplus7-multicast-tv vlan-ids=152” don’t work any more.
I think i have read here in Forum, that this was an ROS Bug with “no tagged” IGMP Data on pvid’ed Interfaceses? Sorry. i didn’t find the post.
Is this correct?
What can i do?
ror is 6.49.7
