Hello
Is 100 mbit SFP supported on CRS106-1C-5S?
Is there a diagram available? What kind of switch chip used?
Thanks.
Hello
Thanks.
Yeah, I’m also interested about 100M (155M) SFP support in CRS106-1C-5S.
Morning Both,
I also have been looking for the answer on this,
I contacted MikroTik Support and they kindly directed me to the Wiki page which has got some updated info
in short - yes the CRS106-1C-5S supports 100mb Fibre SFP Modules
Kev
Thanks for the update, however it states:
Combo interface SFP part on below mentioned devices is compatible with fast ethernet fiber links.
Is that true that only 1 SFP that is combo supports 100 mbit? That’s unclear.
Can anyone with device on hand test that?
Thanks a lot.
No probs
Indeed if you use the Combo port - its only that combo one which is able to do the 100mb SFP (or 1Gb SFP) as the other SFP will be 1Gb/10Gb (SFP/SFP+ )
from reading the spec sheet info
Just double checked with image below which states SFP+ - SFP → Combo
http://shop.meconet.de/images/product_images/original_images/117101_1__117101-2.jpg
Edit –
sorry the above was mentioning the CCR1009-1C models
The 106 is a 1Gb only on SFP 1 - 5 and on the back its 100/1000 SFP / Eth
