CRS106-1c-5s Throughput
Hello guys, Can anyone please give me some info about crs106-1c-5s throughput? As it is running on Router OS not SWOS what will be the maximum through put if i use it as normal sfp switch.
Regards,
It’s a switch. So throughput is the sum of all port speeds :slight_smile:
Hi Normis, Someone told me if I use it with bridge functionality then CPU goes 100% at 70Mbps data transferring. Correct me if I’m wrong.
Sent from my iPhone using Tapatalk
Having a usual bridge, the packet forwarding will be off-loaded to the switch. Only when you enable functions not supported by bridge for offloading in hardware, will the switching be done in software.
