So, I need a bit more performance from this. The CPU frequency setting offers choices of:
500
550
600
650
700
750mhz
Is it safe to run this at 750mhz?
500
550
600
650
700
750mhz
You can read the warning message of changing CPU or memory frequencies here https://wiki.mikrotik.com/wiki/Manual:RouterBOARD_settings#Settings
CRS109 is a switch, if you use it as a router then the performance will not be as good as if you were using a Router model…
