CRS109-8G-1S-2HnD-IN - Using it as a WiFi Switch (Not router
Hi folks,
I purchased 3 units, and configured the first one and exported the script (attached)
Note1: These 3 units are identical and are NOT to be routers but acting as a switch with WiFi.
Note2: I want all ports to be bridged / switched.
Couple of problems.
  1. The Private WiFi and Guest WiFi are identical, the Guest WiFi should not be able to see the internal network just the Internet.
  2. If I restore the script on the other 2 units with the IP address changed they are not discoverable on the network with WinBox. If I plug in my laptop directly to the switch only that switch shows up on WinBox.
Latest firmware 6.22 running on all 3 units.
All I want at the end of the day is a 8 port switch with 2 WiFi networks, 1 being Guest and 1 being Private.
Any scripts or suggestions to making this happen is greatly appreciated.
first.rsc (4.02 KB)
